Commonwealth Bank Group
How to refer REST service hosted in Pega (Expecting a request from an external system) from an activity (connect activity that is specified from an Assignment Service shape) ? What is the method used and what are the inputs required ?
Hi Rashmi Raj,
Would you like to simulate the REST service call?
-Shan
Yes that's right Shan.
I am expecting an external system to contact Pega with some information and we from Pega respond with a newly created case for the same.
Rashmi
Hi Shan,
Thanks for your inputs. Currently I am able to do the above simulation mentioned by you. The simulation works fine. Do I have to call the REST service from a flow (Assignment Service shape) for an external system to contact me ? Or just setting up the service is enough for it to work ?
Rashmi
Rashmi,
I think this should be good. However, depending on your use case how you invoke the REST service might differ. In one of our use cases, we invoke the REST service directly as below :
YOURAPPLICATIONURL/PRRestService/CUSTOMER PACKAGENAME/CUSTOMER CLASSNAME/CUSTOMER METHOD NAME
Please let me know, if you need further help with this.
-Shan
Tata Consultancy Services Ltd
Hi We Create RestService,,and it is working fine when we test in pega cloude...but i want how to test my service with restclient..for ur information see bellow url
https://paex17-ap.pegacloud.com/prweb/PRServlet/WBGTakeLoanData/Person/GetPerSonInfo_two/TakeLoan we test this one but i am getting bellow error
- Status Code: 304 Not Modified
- Connection: Keep-Alive
- Date: Fri, 16 Sep 2016 07:19:36 GMT
- Keep-Alive: timeout=5, max=100
- Server: Apache/2.2.24 (Unix) mod_ssl/2.2.24 OpenSSL/1.0.0-fips mod_jk/1.2.37 can any one exolaine how to do it and how to call assiganment flow give an small example
Freelancing
Hi Shiva,
I have the similar scenario , did you find any solution for this , please let me know .
Chandan
