Not able to generate pdf from stream, if I have row repeats in the Section
I am having a section where I used row repeats. And the requirement is to show the section in pdf but not the Launch harness.
I tried the HTMLToPDF and used Code-Pega-PDF.View , but empty pdf getting generated.
If I give any static layouts in the section its fine pdf is generating with proper layout. But the dynamic layouts are not coming.
Could you please help me out here ?
Hi
I notified the relevant team to look into this and reply to you.
Regards
dimis
