JP Morgan
Upgrading Pega 5.5 to Pega 7.2 using single schema and then splitting the schema
We are upgrading Pega 5.5 to Pega 7.2 using single schema and then splitting the schema.
With reference to guide pega-72-platform-upgrade-guid.pdf. I am some queries/concerns as mentioned below. I would be happy if someone could answer these concerns/queries. Thanks
Step1 : Migrating the rules tables with one database (page 44 & 45)
Use the migrate script to migrate the rules tables and other required database objects from the existing rules schema to the new schema
pega.source.rules.schema=original data schema name
pega.target.rules.schema=new rules schema name
pega.target.data.schema=original data schema name
Note: If pega.target.data.schema is blank, the rules schema is used by default.
Query/concern:
1. why "original data schema name" is mentioned in source.rules.schema and target.data.schema. As per my understanding the target.data.schema should by PEGADATA.
2. Also in this step we are migrating rules table from source.rules.schema to target.rules.schema then why target.data.schema needs to be mentioned?
Step2 : Upgrading the migrated rules schema (page 46)
pega.rules.schema=new-rules-schema-name
pega.data.schema=new-rules-schema-name
Step3 : Generating rules schema objects (page 48)
pega.source.rules.schema=original rules schema
Query/concern:
1. In this step we are generating rules schema objects then why target.data.schema is mentioned?
2. why target.data.schema is mentioned as orginal data schema, shouldn't it the target.data.schema be PEGADATA?
Step4 : Upgrading the data schema (page 72)
pega.data.schema=original-data-schema-name
Query/concern:
1. In this step we are upgrading data schema then why rules.schema is mentioned?
