inautix
Last activity: 12 Mar 2016 13:05 EST
home page refresh
Hi
how to make sure the home page is refreshed when you return from a work item ? right now home page does not reflect the chnged work item status untill we manually refresh it
Thank you
Cognizant
Please check the section in the harness and look in to it's properties.
inautix
Hi @shivendrak6931 .
I looked into properties and checked refresh when active and defer load contents. Its still not working as expected. Please provide some more insight on what can be done.
Thank you
Incessant Technologies
What version you are using. Can you pls explain little more details.
Like your are facing issue on Pop-screen on which the work item is processeing and refresh is not happening on home page.
inautix
We are using version Pega 7. Actually while working on a work item when we procces it and it's status changes after closing the work item when we click on the dashboard , over there changed work item status is not reflected untill we maunally refresh it from the IE refresh button. We want that as soon as we close/return froma work item it's updated status should be reflected.
Please suggest how can we do this.
please try adding "Declare_pzRecentsCache.pxUpdateDateTime Changes" as refresh condition
inautix
Thankyou for the reply . Should i add this condition to Section refresh or harness refresh ?
to Section refresh
could we check the value both on clipboard and DB...[may be it might have not fetched from database...not sure though]
