Repeating grid line item attachement
I wanted to have attachment for each line item of a repeating grid, however the current attachment type field is not available within repeating grid.
Thanks for the feedback. This is on our roadmap.
Any feedback on this? This is a much needed feature.
Thanks!
Hi, Thanks for the follow up. This is still on our roadmap and has not been taken up yet.
Any feedback on this post? I'm also working on the same feature and any response in this regard is much appreciated.
Thanks.
Hello All
I am working on the same requirement is there is any update or fix we do in line item attachment
If you need to be able to do this it requires more advanced configuration in the Designer Studio.
Attachments always get attached directly to the case but you can create auto-populated properties that allow you to reference specific attachments in the context of each embedded item. This requires custom configuration and is not directly supported out of the box without custom configuration on the application side.
we have a similar requirement, any other alternative to achieve without customization?
