Virtusa
Posted: Feb 10, 2016
Last activity: May 22, 2017
Last activity: 22 May 2017 6:14 EDT
Rule Resolution
An application rule lists the following application rulesets, in order:
- Ruleset1:01-05
- Ruleset2:02-03
- Ruleset3:01-17-50
On the system hosting the application there are five (5) instances of the section rule, XYZ
Rule | Applies To class | Ruleset & Version | Availability |
A | Org-Div-Work | Ruleset1:01-04-02 | Yes |
B | Org-Div-Work-ABC | Ruleset2:01-02-01 | Blocked |
C | Org-Div-Work-ABC | Ruleset3:01-17-99 | Withdrawn |
D | Org-Div-Work | Ruleset2:02-02-01 | Yes |
E | Org-Div-Work-ABC | Ruleset3:01-09-12 | Yes |
Which version of section XYZ does the system attempt to use when processing a case of type ABC?
Rule D.
Rule B.
Rule E.
Rule A.
Rule C.
