PEGA
PEGA
Posted: Nov 24, 2015
Last activity: Nov 24, 2015
Last activity: 24 Nov 2015 16:10 EST
question on rule resolution
Consider the following scenario:
The PIPFW application has the following application RuleSets:
- PIPFW:01-01
- PIPFWInt:01-01
- LES:01-01
- LESCatalog:01-01-01
- LESInt:01-01
A rule with an applies-to class of “ABC-FW-LoanReq-Work-Autoloan” calls “Rule123”. There are 6 copies of Rule123 in the system, with the Applies To Class, RuleSet Version, and Availability, as follows:
- Option A: ABC-FW-LoanReq-Work, PIPFW:01-01-05, Availability = Withdrawn
- Option B: ABC-FW-LoanReq-Work, PIPFW:01-01-03, Availability = Yes
- Option C: ABC-FW-LoanReq-Work, LESCatalog:01-01-05, Availability = Withdrawn
- Option D: ABC-FW-LoanReq-Work, LESCatalog:01-01-01, Availability = Yes
- Option E: ABC-FW-LoanReq-, PIPFW:01-01-03, Availability = Yes
- Option F: ABC-FW-LoanReq-, LESCatalog:01-01-01, Availability = Yes
ANSWER is 'Option D'
can someone explain?
