NIIT Technologies Limited
Last activity: 26 Oct 2015 0:54 EDT
Rule resolution exercise - 4th question
What should be the correct answer for below question?
I feel it's - D, error raised.
But exercise saying it's I, no error raised?
Also, what is the difference between 3rd and 4th question?
Consider the following scenario:
The PIPFW application has the following application RuleSets:
- PIPFW:01-01
- PIPFWInt:01-01
- LES:01-01
- LESCatalog:01-01-01
- LESInt:01-01
A rule with an applies-to class of “ABC-FW-LoanReq-Work-Autoloan” calls “Rule123”. There are 9 copies of Rule123 in the system as shown below.
- Option A: ABC-FW-LoanReq-Work, PIPFW:01-01-05, Availability = Withdrawn
- Option B: ABC-FW-LoanReq-Work, PIPFW:01-01-03, Availability = Yes
- Option C: ABC-FW-LoanReq-Work, LESCatalog:01-01-05, Availability = No/Draft
- Option D: ABC-FW-LoanReq-Work, LESCatalog:01-01-03, Availability = Blocked
- Option E: ABC-FW-LoanReq-, PIPFW:01-01-05, Availability = Withdrawn
- Option F: ABC-FW-LoanReq-, PIPFW:01-01-03, Availability = Final
- Option G: ABC-FW-LoanReq-, LESCatalog:01-01-05, Availability = Yes
- Option H: ABC-FW-LoanReq-, LESCatalog:01-01-03, Availability = Yes
- Option I: @baseclass, Pega-RULES: 07-10-99, Availability = Yes
Which rule is chosen by Rule Resolution? (Choose One)
