CVS
Last activity: 4 Nov 2016 22:24 EDT
Rule Resolution Process
In the lesson Rule Resolution Process it says
1.Check the rule cache.  If the rule is present in the cache, go to Step 8.
and the steps 8 and 9 are
8.Find the best instance (and check to make sure there is not a duplicate rule).
9.Check that the Availability is not set to BLOCKED.
Why do we have to check for the Blocked if the rule is already present in the Cache. Can a rule be changed from Available to Blocked by someone else while it was sitting in the cache.It would not even be picked up if its BLOCKED in the first place. even if the availability changes, does not the system pulse invalidate that entry from the cache.
Thnaks,
Pradeep
