Atos
Last activity: 7 Apr 2017 7:08 EDT
Class mapping
In my case Class MyAtos-LeaveRecordApp-Work is mapped to table PEGA_DATA.pc_MyAtos_LeaveRecordApp_Work in database PegaDATA. So how and where should i find this table in pega in order to see the table structure . I tried to find out the table but i didnt get it . Please tell me the approach to reach it.
Thanks in advance
Dipak Khade
In the top right corner you have a search bar where you can type any name from any rule, table or anything in your application and can be found. If you don't remember exactly the name, just press "enter" without entering nothing and you will see you application structure.
Hope you can find it, if not make sure you are in the right application (click application menu and then on switch application and verify your application is selected)
