Capgemini Norway
NO
Last activity: 12 Jan 2016 2:39 EST
PRPC 6.3 installation problem with Oracle 11g in Windows 10 64 bit.
Targets:Installation (it may take several minutes),Next Step
Unable to locate tools.jar. Expected to find it in C:\Program Files\Java\jre1.8.0_40\lib\tools.jar
Buildfile: F:\Pega Personal Edition\PRPC-v6.3\.\pegaGuiInstallerTemp\build.xml
Installation Preparation:
[echo] calling install ....
Initialization:
[delete] Deleting: F:\Pega Personal Edition\PRPC-v6.3\scripts\resume.properties
[delete] Deleting directory F:\Pega Personal Edition\PRPC-v6.3\scripts\taskRuntimes
[mkdir] Created dir: F:\Pega Personal Edition\PRPC-v6.3\scripts\taskRuntimes
[delete] Deleting: F:\Pega Personal Edition\PRPC-v6.3\scripts\logs\Warnings.log
Could not read file : F:\Pega Personal Edition\PRPC-v6.3\scripts/setupDatabase.properties
[propertyfile] Creating new property file: F:\Pega Personal Edition\PRPC-v6.3\scripts\resume.properties
[propertyfile] Updating property file: F:\Pega Personal Edition\PRPC-v6.3\scripts\resume.properties
Found 46811532KB of free space on 'F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp'
[mkdir] Created dir: F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp\PegaInstallTemp-02-January-2016-23.26.45\load
[mkdir] Created dir: F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp\PegaInstallTemp-02-January-2016-23.26.45\pr_temp
[touch] Creating F:\Pega Personal Edition\PRPC-v6.3\scripts\logs\Warnings.log
[echo] Using F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp/PegaInstallTemp-02-January-2016-23.26.45 for install scratch space...
[unzip] Expanding: F:\Pega Personal Edition\PRPC-v6.3\archives\prweb.war into F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp\PegaInstallTemp-02-January-2016-23.26.45\load
[unzip] Expanding: F:\Pega Personal Edition\PRPC-v6.3\archives\pegadbinstall-classes.zip into F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp\PegaInstallTemp-02-January-2016-23.26.45\load
[copy] Copying 1 file to F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp\PegaInstallTemp-02-January-2016-23.26.45\load\lib
[copy] Copying 1 file to F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp\PegaInstallTemp-02-January-2016-23.26.45\load\WEB-INF\classes
Checking Configuration Files:
Processing Configuration Files:
[propertyfile] Creating new property file: F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp\PegaInstallTemp-02-January-2016-23.26.45\prbootstrap.properties
Configuration:
[echo] Database Type: oracledate
[echo] JDBC Driver JAR: C:\Users\Sayantan\Documents\ojdbc7.jar
[echo] Bootstrap Config: F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp/PegaInstallTemp-02-January-2016-23.26.45/prbootstrap.properties
[echo] PegaRULES Config: F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp/PegaInstallTemp-02-January-2016-23.26.45/prconfig.xml
[echo] PegaRULES Logging Config: F:\Pega Personal Edition\PRPC-v6.3\pegaGuiInstallerTemp/PegaInstallTemp-02-January-2016-23.26.45/prlogging.xml
UDF Generation:
UDF Generation Inner:
Install UDF Jar:
[java] Jan 02, 2016 11:27:22 PM com.pega.pegarules.install.DatabaseLibraryLoader writeMessage
[java] INFO: Loading user-defined functions into the database.
[java] INFO: Using an Oracle database.
[java] Jan 02, 2016 11:27:23 PM com.pega.pegarules.install.DatabaseLibraryLoader writeMessage
[java] INFO: Getting the jar file from F:\Pega Personal Edition\PRPC-v6.3\scripts/../archives/udf/prreadstream.jar
[java] INFO: Adding com/pega/pegarules/data/internal/clipboard/directstream/BadReferenceException.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/internal/clipboard/directstream/BadStreamDataException.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/internal/clipboard/directstream/ByteArrayUtil.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/internal/clipboard/directstream/DirectStream.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/internal/clipboard/directstream/DirectStreamEnvironmentAdapter.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/internal/clipboard/directstream/InflaterV7.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/internal/clipboard/directstream/PropertyReferenceUtilities.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/BasicEnvironmentAdapter.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/CachedDirectStream.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/DirectStreamReader.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderBase.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderDB2LUW.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderDB2ZOS.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/FixedCacheMap.class to the list for addition to the table.
[java] INFO: Adding com/pega/pegarules/data/udf/directstreamreader/UnsupportedFeatureException.class to the list for addition to the table.
[java] Jan 02, 2016 11:27:24 PM com.pega.pegarules.install.DatabaseLibraryLoader writeMessage
[java] INFO: Created temporary table pz_blobtable
[java] INFO: com/pega/pegarules/data/internal/clipboard/directstream/BadReferenceException.class inserted into table.
[java] INFO: com/pega/pegarules/data/internal/clipboard/directstream/BadStreamDataException.class inserted into table.
[java] INFO: com/pega/pegarules/data/internal/clipboard/directstream/ByteArrayUtil.class inserted into table.
[java] INFO: com/pega/pegarules/data/internal/clipboard/directstream/DirectStream.class inserted into table.
[java] INFO: com/pega/pegarules/data/internal/clipboard/directstream/DirectStreamEnvironmentAdapter.class inserted into table.
[java] INFO: com/pega/pegarules/data/internal/clipboard/directstream/InflaterV7.class inserted into table.
[java] INFO: com/pega/pegarules/data/internal/clipboard/directstream/PropertyReferenceUtilities.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/BasicEnvironmentAdapter.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/CachedDirectStream.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/DirectStreamReader.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderBase.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderDB2LUW.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/DirectStreamReaderDB2ZOS.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/FixedCacheMap.class inserted into table.
[java] INFO: com/pega/pegarules/data/udf/directstreamreader/UnsupportedFeatureException.class inserted into table.
[java] INFO: Temporary table pz_blobtable dropped.
[java] WARNING: Encountered database error attempting to load jar into Oracle: ORA-29538: Java not installed
[java]
[java] java.sql.SQLException: ORA-29538: Java not installed
[java]
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450)
[java] at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:399)
[java] at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1017)
[java] at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:655)
[java] at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249)
[java] at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:566)
[java] at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:202)
[java] at oracle.jdbc.driver.T4CStatement.doOall8(T4CStatement.java:45)
[java] at oracle.jdbc.driver.T4CStatement.executeForRows(T4CStatement.java:933)
[java] at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1075)
[java] at oracle.jdbc.driver.OracleStatement.executeUpdateInternal(OracleStatement.java:1640)
[java] at oracle.jdbc.driver.OracleStatement.executeUpdate(OracleStatement.java:1603)
[java] at oracle.jdbc.driver.OracleStatementWrapper.executeUpdate(OracleStatementWrapper.java:308)
[java] at com.pega.pegarules.install.DatabaseLibraryLoader.installJarOnOracle(DatabaseLibraryLoader.java:433)
[java] at com.pega.pegarules.install.DatabaseLibraryLoader.main(DatabaseLibraryLoader.java:175)
[java]
[java] INFO:
[java] *****************************************************************************************************
[java]
[java] Encountered database error attempting to load UDF library onto Oracle, clean schema before running again.
[java]
