syntel
Last activity: 8 Sep 2015 13:03 EDT
Installation issue in Pega 7.1.7
Hi Team,
Few months before i installed Pega 7.1.7 without any issue and was working on the excerise. Recently i had issues in my system, so i downloaded the Pega 7.1.7 again and tried to install . But when i click the Install.BAT file to install the Pega 7.1.7 i'm getting the below error.
"Windows cannot find 'C:\Users\Janaki\AppData\Local\Temp\wzfe9c\jdk1.7.0_71\bin\java' Make sure you typed the name correctly , and then try again " .
A) I downloaded Pega 7.1.7 in E drive and i have Jdk1.7.0._71 also in E drive , but when i click the Install.BAT file i'm getting the above error message which is showing it as "C" drive . Can some one help me to know when i click the Install.BAT file by default how it is refering the above the path and from where it is getting this path.
B) Aswell could you please let me know before Installing PEGA in our system, do i need to Install JAVA in my system, bcz in the Zip file which i downloaded for pega 7.1.7 also holds the Jdk Proprietary information hidden file.
