Using connecters
Can any one show a simple example how to use a connecter to access webservices
In order to use Connectors you should have wsdl file. Please look into the below article on how to test a SOAP connector.
https://docs-previous.pega.com/how-test-soap-connector-using-sample-data
How to do it in pega7?
My requirement is to accept a value (temperature in celsius ) in a text box and display corresponding fahren heat value in another textbox.By calling the following wsdl url ...
http://www.w3schools.com/webservices/tempconvert.asmx?WSDL
Please explain how to do this in pega 7.
Use Connect Soap rule to get temperature in an appropriate property. Call this connect soap rule in the flow in an integrator rule.
