StaidLogic
Last activity: 15 Jul 2015 5:19 EDT
REST connector response issue
I am able to pass the request message via REST connector into external system but I am receiving the failure response in clip board .
Could you please let me know the root cause of the issue !
Failure Response from Pega:
pyStatusValue Fail: Unexpected HTTP Response code
pxObjClass AEXP-FW-ERM-Int-GDE-V1-ADSSQscore-ADSSQscore
pyStatusMessage the HTTP response code of 500 indicated a server error. The response data may contain a reason.
pyHTTPResponseCode 500
External System Logs"
Below are the logs captured from external system.
10:21:21 PM mpgw error HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false"144623821 error HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false" Proprietary information hidden HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false"0x00030001 mpgw (mpgwAssessmentService): Parse error
10:21:21 PM multistep error HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false"144623821 request HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false" Proprietary information hidden HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false"0x80c00008 mpgw (mpgwGCPClientRiskAssessmentService): rule (mpgwGCPClientRiskAssessmentServiceV1_getRiskAssessment_request_rule): implied action Parse input as XML failed: Incomplete markup or missing document element at offset 0 of http://IPAddress:port/A/AssessmentService/V1/get
10:21:21 PM xmlparse error HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false"144623821 request HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false" Proprietary information hidden HYPERLINK "https://IPAddress:port/system/displayLog?navFrame=false"0x80e003aa mpgw (mpgwAssessmentService): Incomplete markup or missing document element at offset 0 of http://IPAddress:port/A//AssessmentService/V1/get
