Milestone upgrade from Pega 7.1.7 to Pega 7.1.8
I am performing a Pega milestone upgrade from Pega 7.1.7 to Pega 7.1.8.
I have few questions on the upgrade guide and would like to have a response.
1) The binaries (114820_P718-UPD) for the upgrade does not come with a document which describes the upgrade guide and we have to seperately download the guide (Pega718_UpgradeGuide.pdf) from PDN. Is this the intended behavior for any customer performing the upgrade?
2) On Page 21 section "Editing the setupDatabase.properties file" the guide describes: "Skip this section if you will use the IUA to upgrade and you will allow the upgrade process to automatically apply the schema changes".
To me this statement is not clear. Question is - do we need to edit this property file if we do not use IUA?
Do we need to edit this property file if we want the command line script to make the necessary schema changes.
3) On Page 56 point 6. the guide describes "If the system has access to both the PRODUCTION and TEMPORARY databases, enable...." This statement is also not clear.
If we have only once database instance where all the required schemas are available, do we edit the property file for key value pairs specified in this point?
Please share your findings/answers.
Thank you
Titto
