CapitalOne
Default PEGA DateTime Value 19700101T000000.000 GMT ?
If DateTime property does not contain any value then PEGA is assigning default value "19700101T000000.000 GMT" while saving to DB , Is there any specific reason for setting default value ? how it is useful?
I need to store null value in DB if DateTime property does not contain any value , how can we achieve it?
Sudeerkumar Munaga
Proprietary information hidden
Thank you for your query. You mention that if a DateTime property is not set, a default "19700101T000000.000 GMT" is assigned. Could you provide an example of where you have seen this with a screenshot if possible.
The minimum value which can be set for a DateTime property is 01-01-1000 000000.000. The maximum is 31-12-9999 000000.000. This can be done using the function call @(Pega-RULES:DateTime).date(1000, 01, 01).
Andrew Fontenelle
PDN Support Team
Accenture
Hi Fonta,
This is happening by default, in activity - have property set and to a Date time property - if ur assigning blank, then it will set "19700101T000000.000 GMT" this value.
Padmanabhan K
CapitalOne
Hi Padmanabhan,
Is there any specific reason for it ? is there any option to avoid setting default value?
Sudeerkumar Munaga
Synechron
In UI where i am using pxdatetime as control, and i am selecting date from calendar, from where the timestamp get added to the value.
Like for example in calender i am setting Jan 01, 2015, so in the property i can see value like 20150101T040000.000GMT.
So from where this "T040000.000 GMT " is getting add. And if i want to customize the timestamp like "T120000.00GMT"
JP
use "property-remove" instead of using "property-set" to set a blank value for a DateTime property if you want it to be null.
Capgemini India PVT Ltd
Thanks Hong. Property-remove worked.
Areteans Technology
Hello RaunakJ6,
If the property type is datetime, the values always stores time. When it has to store time, it stores in GMT format. If you want to enable user selecting hours,minutes you can do that using pxdatetime control.
Ashok
JP
To avoid default epoch time for datetime properties, you can try below dynamic system settings.
Name |
Purpose |
disableEpochDateTime/ Pega-IntegrationEngine |
When a datetime property is set and the value is empty, it will by default return the epoch datetime (01-jan-1970). Set this value to "true" to have the property return no value. |
Sky Solutions
Hi Hong,so which property did you say to set it to true? and how do I find where this default date is setting and can I remove the default date value?
Kamala
Synechron
Thank You
Wipro Ltd
HI ,
How to Convert 20150801 Date format to 20150801T050000.000 GMT format??
Process 360
You can make use of @(Pega-RULES:DateTime).addToDate("20150801", 0,5, 0, 0)
Synechron
Thanks Ramya. That was useful
Cognizant
Hello Chunzhi_Hong ,
Can you please provide bit more details how can we avoid default epoch time for datetime properties.
we are using PEGA 5.3 version we have the same issue with dafault date time.
Thanks in Advance!!
