Tech Mahindra
Last activity: 11 Aug 2015 2:52 EDT
about correspondence
Hello there,
Right now, I'm at the section "Notifying Users from within a Process" on the chapter "Enforcing Businesss Policies".
And there is article below;
Notifying users of pending assignments
1. Create an email correspondence record in SAE-HRServices-Work that will be used to send task notifications. We suggest using “Task Pending Notification” for the short description.
2. Write a simple notice to the assignee: A new task (______), for case (_____) is in your worklist.
3. Use .pyID to identify the task and .pyCaseID to identify the case number.
4. Configure each of the assignments with the appropriate notification parameters.
On no2 above, I cannot understant what "case (_____) is in your worklist" means.
And because of that, I cannot figure out what no2 and no3 means.
Thank you.
