Naming Convention
The suggested naming convention in the lesson Tips on Developing an application for flow action states that:
"Flow Actions - Use a verb and noun convention for flow actions, for example, Approve Correspondence. A flow action can reference other records. When associated with certain activities, data transforms and validation records, prefix the flow action name with:
- Pre — if used with a pre-activity or data transform; for example, PreApproveCorrespondence
 - Post — if used with a post-activity or data transform; for example, PostApproveCorrespondence
 - Val — if used with a validate record; for example, ValApproveCorrespondence"
I don't think this convention is workable, because a flow action can have pre-action, post-action, and/or validation. So what do you call a flow action that have all of them? PrePostValApproveCorrespondence? That's horribly clumsy. Also, the pre-action, post-action and validation can be added or removed after the flow action is created and it is not that easy to change the name of a rule once it is created. A convention like this won't work.
