Last activity: 17 Jul 2016 22:49 EDT
Exercise system does not start
I am going through the Fundamentals course and am on the first exercise 'Use the Case Manager to Process a Case'. I click on the 'Open Exercise System' link at the bottom of the page and nothing happens. I would appreciate if someone could send me a URL that works.
SG
Dear David,
There was an issue with Pega Academy last weekend. I just ghosted as your account and am able to login to the exercise system. Can you try again?
Teng Hao Chua
Pega Academy Support Team
Allianz Deutschland
DE
I would like open the exercise system "Adding Stages to the Case Type". It open, then I write the User Name and the password an nothing happend. Please help me.
SG
Dear Petra,
The username and password is obtained from the instructions in the exercise, and not your PDN username/password. Which username and password did you use?
Teng Hao Chua
Allianz Deutschland
DE
For this exercise, you will be performing the role of System Architect / Developer.
- User Name: Developer01
- Password: password
SG
Dear Petra,
It appears you may have accidentally deleted the HRServices application rule 2 days ago! I have recreated it and you should now be able to login using Developer01.
Teng Hao Chua
Allianz Deutschland
DE
Thank you very much.
Tata Consultancy Services Limited
I am unable to login to exercise system 'Use the Application Wizard – Application Express'
when i try to use the below details, nothing happens
Password: password
Please can you help
SG
Dear Shravan,
In your case, your Employee Reimbursement application had been deleted about an hour ago. It's been restored and you should now be able to login.
Teng Hao Chua
Thank you
I have messed up Employee Reimbursement application, is it possible to delete this and start fresh??
Shravan
SG
Dear Shravan,
It may be easier for you to create another application using a different name, e.g. WorkerReimbursement (swapping Employee with Worker). This will allow you to continue working with your current exercise system by creating a new application.
Teng Hao Chua
HSBC
BR
Hello Chuat,
I'm experiencing a similar issue, but I managed to login to Developer01 back, the main problem is when I try to use the Application shortname, and it says "** An implementation ruleset with the name EmpReimb already exists." - meaning I can't just recreate a new one, right? I'll later need to use it.
Is there a way to delete this ruleset? Where, please?
Diego
ES
SG
Dear DiegoA85,
What username/password did you use for the "Adding Stages to the Case Type" exercise?
Teng Hao Chua
Diego
ES
I used de user/pass:
These are the dates that are indicated in the "Adding Stages to the Case Type" Scenario
Diego
ES
Please. Can anybody help me with the problem?
I can't advance with the course.
SG
Dear Diego,
Your issue is similar to so many others before you! You had the Employee:01-01-01 Application rule deleted and this is causing an issue for Developer01 to login, because this is the default access group associated with this operator!
I have restored the rule, so you should be able to login now.
Teng Hao Chua
Diego
ES
Thank you so much CHUAT.
UHG
I am going through the Fundamentals course and am on the first exercise 'Use the Case Manager to Process a Case'. I click on the 'Open Exercise System' link at the bottom of the page and nothing happens. Please let me know the proper URL to login Open Exercise system
The system is up. I am able to connect to the exercise system for the Fundamentals 7.1 course via the same link you are mentioning without difficulty. Can you please log out of Pega Academy and PDN, log back in and try the link again please?
Let us know if the problem persists.
Kind regards,
Bob Lloyd
Pega Academy Self-study Support Team
When you click the Open exercise system link, be sure that popups are enabled. If you are using the Chrome browser, you will see a small icon at the top right of your screen, that has a red X. Click this to enable pop-ups.
W&W
DE
Dear all,
I'm going through the Fundamentals Course. Since yesterday I am not able to access the exercise system by using following credentials:
Username: Developer01
Password: password
I type in those credentials and nothing happens. The Site only reloads and I have to type in the credentials mentioned above. This is a never ending loop.
I succeeded once to get access with the Developer01 user and tried to create a New Application. But then after creating this application I got into this endless loop.
Can you help me please?
Thanks in advance!
Best regards,
Guido
Swedbank IT
LT
I have lost access to the exercise system (when logging in as Developer01) after deleting the Employee Reimbursement application.
Could it be restored?
Thank you!
