Working service account unable to access System Management Console, ADMN0022E error.
Using a known working service account I can not access the System Management console, but if I use my personal credentials I can access it. I have confirmed this ID is working in other environments, but in a new rebuild we are working on it will not work. Here is the error that gets thrown:
MSG:
Failed to get mbean name
Failed to get the attribute
ADMN0022E: Access is denied for the getName operation on web MBean because of insufficient or empty credentials.
Stack Trace:
com.pega.jmx.ui.util.JMXClientException: Failed to get mbean name Failed to get the attribute ADMN0022E: Access is denied for the getName operation on web MBean because of insufficient or empty credentials. at com.pega.jmx.ui.util.JMXClientException.wrap(JMXClientException.java:49) at com.pega.jmx.ui.action.AuthenticateAction.execute(AuthenticateAction.java:272) at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:484) at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:274) at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1480) at org.apache.struts.action.ActionServlet.doGet(ActionServlet.java:506) at javax.servlet.http.HttpServlet.service(HttpServlet.java:718) at javax.servlet.http.HttpServlet.service(HttpServlet.java:831) at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1661) at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:944) at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:507) at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:181) at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:91) at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:878) at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1592) at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:191) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:453) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:515) at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:306) at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:84) at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175) at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217) at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161) at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138) at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204) at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775) at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905) at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1660) Caused by: java.lang.Exception: Failed to get mbean name Failed to get the attribute ADMN0022E: Access is denied for the getName operation on web MBean because of insufficient or empty credentials. at com.pega.jmx.connection.managenodes.Node.getMBeanName(Node.java:235) at com.pega.jmx.ui.action.AuthenticateAction.execute(AuthenticateAction.java:160) ... 26 more
