    BNZ
NZ
Last activity: 8 Jun 2016 22:53 EDT
Will IGNORE DUPLICATE FILE NAMES work even if we are not saving LOG-SERVICE-FILE instances
IGNORE DUPLICATE FILE NAMES? makes the system to check the instances of LOG-SERVICE-FILE class, in order to avoid processing of files with same file name. However I'm not able to understand the system behavior in the below scenarios. Could someone please help me.
1. Will PRPC process the file with same name after some time or It will ignore that file until the LOG-SERVICE-FILE instances are deleted?
2. If I select "ignore duplicate file names?" and don't select "Persist LOG-SERVICE-FILE instances", what will happen if I place same file in the secure directory again?
