Accenture
Last activity: 12 Oct 2015 7:49 EDT
Where can we configure Requestor timeout and Lock Timeout? Which data instance need to be set for this setting?
Where can we configure Requestor timeout and Lock Timeout ?
Which data instance need to be created for this ?
Pegasystems
You can configure a system wide time out on the System record. You can configure a lock timeout for a case in the case designer Locking configuration or on the Advanced tab in the case type rule.
Accenture
For System wide lock timeout which data instance i need to create?
Pegasystems
For version 7.x?
Open Record Explorer and click SysAdmin/System. You will see a list of 1 or more System records on the right. Select your system and you will be able to edit the lock timeout. This assumes that you have sufficient privileges to edit this record.
Pegasystems
In the Access Group you can set an Authentication timeout (see help): Enter a number of seconds after which the system challenges idle browser sessions (for users of this access group), asking users to re-enter their Operator ID and password. This timeout event does not cause session context or clipboard contents to be lost.
Accenture
Morgan Stanley
Check the specific requestor type instances for Lock timeout setting.
Pega
For Requestor timeout can be mentioned at Access Group data instance Access Control section->Authentication timeout -->number of seconds after which the system challenges idle browser sessions.
LockTimeout:- can be mentioned at different levels like Data-Admin-System instance defned under sysAdmin-->System instance
Case type rule you can provide under details tab or under Locking section can provide under input box of
