What is ActivityStatusExceptionHandler?
What are the conditions for which this is called? Not documented anywhere.
Filed as SR-126652.
Filed as SR-126652.
Let's say , I have an activity with java step having some code which may potentially cause some runtime exception and if it is not handled well then activityStatusExceptionHandler will get executed. In simple java step which has java source code that may produce unhanded exceptions like below one.
Hope this helps.
Image didn't come through.
13 months later, struck upon the idea to override ActivityStatusExceptionHandler so that it logs to the server when there's a problem.
Can't see how I didn't think of this sooner.
