VMWare Settings for Pega LSA 8.8.2 Linux Lite VM for better Performance
Purpose/Issue-
As part of Pega CPLSA mission challenges we can execute the solution on VM instance 8.8.2 Linux Lite VM. i had downloaded VMWare workstation 17 for Non-commercial use in Windows 10 64 bit.
when i installed it and set the loaded the ova file LinuxLite-Pega882 . My PC was almost having Zero Performance , no screen was loading and everything was stuck.
My PC configuration was as below, i had 8 GB ram and core i5 processor.
when i initially setup the VMWare settings for LinuxLite-Pega882 i had set RAM as 8 GB and Cores to 4 in the VM settings.
Solution-
I had reduced the loaded VM settings LinuxLite-Pega882 set RAM as 6 GB and Cores to 3 which resolved performance issue and slowness , hope this helps to everyone
Note - as per pega recommendations below are required configurations to setup VM
Minimum 12 GB RAM free for the VM to use (in addition to that required by your host) and At least 25 GB of free disk space.
Below is reference document link for more info
