WellsFargo
Last activity: 17 Jun 2016 9:46 EDT
Stack Error while we creating child case
While creating a child case we are getting Stack error like below
A Processing Error has Occured
example:Object key class pyID
Error Message<%=StringUtils.decodeCrossOSString(Param.pyErrorMessage);%>
please provide your suggestions to resolve this issue
Ai4Process
HI,
Could you restart PVS (reboot -h now) close your browser, clear the cache and try again?
Damien
WellsFargo
Hi, Thanks for your reply..we already tried that one.......all are my team mates got the same issue even we cleared the cache and restarted the browser
Ai4Process
Which version are you using?
WellsFargo
Pega 7.1.9
Ai4Process
ok,
When does this error appear? At design time or run time?
How do you create/instantiate your cases?
Could you give me more inputs in order to reproduce?
Damien
WellsFargo
Its appearing at runtime..we have cover object and its opened. we are trying to create a child case and append to the cover object. means we are opening the cover object from UI and on click of a button we are calling an activity to create child object flow. when we performing the action in harness its shows the error, but when we reopen the cover object , the child cases got created to the parent Cover Object.
Virtusa
Hi ,
Is this issue resolved ?
I am als facing this issue ,was there any workaround for this
Shiva
could be a sample data issue...
Updated: 17 Mar 2016 11:48 EDT
There may be issues with double cross-scripting a pyID value.
So you are able to call your child case-creating Activity fine but then see an error in the UI afterward?
What do your pyID values look like? Do they contain any characters that need to be HTML encoded / escaped?
Hi Pedel, Good morning!
- pyID = C-1, C-2 so on...
- we faced this issue
- by clearing the work objects (test environment) we were able to get away from the issue.
- not sure of the real cause as it is sporadic in nature too.
- could you please guide how to debug the issue.
Thank you!
sahup1
BCBSMA
Is there a hotfix for this issue in ML9? We just started to see this problem in development this morning. I have created a ticket and hope to get some assistance but figured I would ask here too.
could you please add the ticket ID [SR ID] here please...Thank you!
Updated: 6 May 2016 9:52 EDT
CBA
We are also facing the same issue....
We are using version 7.1.9 where we are creating a child case by clicking on submit button of the parent case. In our case the issue is intermitent as for the same set of data some time is working fine but some time it gives us the below error message.
Our pyID is PA-515, PA514....
Error Message:-
Cover Key override:** Unable to open an instance using the given inputs: PegaMfg-AMS-Work PEGAMFG-AMS-WORK-WR
A processing error has occurred
Object key PEGAMFG-AMS-WORK-WR PA-515
Error Message <%= StringUtils.decodeCrossOSString(Param.pyErrorMessage); %>
Stack Trace
Can any one please guide on the work around on this issue.
Thank you for your help!
Capgemini
NO
Facing the Same Issue, Anyone Got any solution yet?
