FTB
SSO is not working after upgrade to PRPC7 ML7
SSO is not working and found the below log entry:
ERROR|WebContainer : 3|2015-04-24 09:13:20,074|com.pega.pegarules.session.internal.mgmt.authentication.SchemePRCustom|Authentication failed because the constructed Data-Admin-Operator-ID instance failed to pass validation. The most likely cause for this is that your Data-Admin-AuthService record attempts to map directory attributes to PROPERTIES THAT DO NOT BELONG TO DATA-ADMIN-OPERATOR-ID class. Check your D-A-AuthService record for bad entries or typos.|H13A8FEBBFC89357260D59C968B3AFBD5x1|
