Virtusa Inc
Virtusa Inc
Virtusa Inc
Posted: Jun 10, 2015
Last activity: Oct 26, 2015
Last activity: 26 Oct 2015 2:25 EDT
Signature Capture control
have anyone tried using the signature capture control and how it is getting persisted. I have an requirement where the signature captured from User have to be sent to another application using webservices. is this possible ?
Thanks in advance.
Yes. The Signature Capture control allows you to capture a user's signature both from a desktop application and within an app using the Pega 7 mobile application. Once a user has input a signature, it is added to the work item or case as an image attachment. You can learn more about the new Signature Capture Control in this PDN article:
https://pdn.pega.com/user-interface/how-to-use-the-signature-capture-control
You can then send the signature image attachment to another application using a SOAP Connector. To learn more about how to Integrate Pega Applications with other systems using SOAP (and other Web Services) Connectors you can refer to the following PDN article:
https://pdn.pega.com/browse/prpc-topics/integration
Henry
Pega Academy
