Infosys
Last activity: 8 Feb 2016 9:16 EST
Save as of a circumstanced section giving error
We are trying to save as one section (Pega 7.1.8) which has circumstance property defined in higher ruleset version. But while saving as its giving error as below. Though the circumstance is defined on pxRequestor.pxPortal. there is no rule with circumstance property OperatorID.pyUserIdentifier.
Generally, if circumstance has already been defined using (let's say) property 'xxx' then you cannot use 'yyy' property also. If you want to use more than one property you can go for a circumstance template and circumstance definition. I am not very clear from the question whether that is what is the root cause, can you mention more details like a) while or before (through private edit) doing save as, are you trying to change anything? b) Which version is the base rule and circumstanced rule and what version are you trying to save as? c) are there any sibling rules for this section in other RSVs?
