VirtusaPolaris
Last activity: 17 Oct 2018 11:10 EDT
UpgradePegaMarketing activity gives RDB-SAVE Error
After upgrade of Pega Marketing from 7.2.1 to 7.3.1, while running UpgradePegaMarketing activity I am able to see error in log file - Error in RDB-Save.
com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: 947 SQLState: 42000 Message: ORA-00947: not enough values
DatabaseException caused by prior exception: java.sql.SQLSyntaxErrorException: ORA-00947: not enough values
| SQL Code: 947 | SQL State: 42000
Steps to reproduce:
- Upgrade from Pega Marketing system 7.2.1 to Pega Marketing 7.31
- Run UpgradePegaMarketing activity located in the PegaMKT-Install class with check boxes for UpgradeFrom721To722 & UpgradeFrom722To731 are checked.
Can you please attach the full Pega log of the node in which the upgrade scripts was run ? Also the XML output what you got after the upgrade was run.
Also please check if you have HFix-39276 and other mandatory hotfixes installed for PM 7.31 before running the upgrade scripts.
