PSC Top Participants - 2019
The PSC Top Participants program aims to recognize quality participation on our community and is exclusively designed for non-Pega employees!
In the below list you will see our Top 5 participants in every quarter of 2019. These participants are selected based on their quality of interactions.
Join the PSC Moderation Team in congratulating the winners!
The PSC Top 5 Participants in Q4 2019 are:
@vaspoz @Bhavya_Incessant @Deva_Prathapaneni @Anthony_Gourtay @JAYACHANDRA Reddy K
The PSC Top 5 Participants in Q3 2019 are:
@N.SenSharma @JAYACHANDRA Reddy K @EngincanY @LoicM950
The PSC Top 5 Participants in Q2 2019 are: @Bhavya_Incessant, @BobReawaruw, @JAYACHANDRA Reddy K @EngincanY, @SatishKumarL5551
The PSC Top 5 Participants in Q1 2019 are: @anthonymcgriff, @SiddhantJivane, @Srimathi, @ShuvadeepD, and @Ratan
Wondering how YOU could get into this list? Here are some tips!
- Participate in discussions to add value
- Make sure to drive the discussions on your post through active responses, if you found an answer - always update your post with the resolution and click the Correct Answer link!
- Share your knowledge through detailed posts - We call them Developer Knowledge Shares!
Below are the Developer Knowledge Share posts posted by our Top Participants!
Using Message Definitions and Message Manifest by Anthony McGriff
Solution: Adding attachment to each page inside the page list by Siddhant Suryakant Jivane
Solution:Login screen is not coming, after deployment of RAP which contains customized Login screen by Siddhant Suryakant Jivane
Add Watermark in PDF by Srimathi Herath
Apache POI – Parsing Excel Workbook by Shuvadeep Das
Column repeat in Pega 7.4 and above by Ratan Balaji
Correctly delete case attachments after import? by Bob Reawaruw
How to: change/add/remove class keys? by Bob Reawaruw
