Project Management Framework for Multiple Pega Projects
Hi - would appreciate some advice on the following:
1. Is it possible to use Pega Project Management Framework (one product) to coordinate requirements / sprints for multiple Pega applications which are built on the same base layer but which are initiated at different times? We are facing the issue of multiple projects from different Business teams, which will result in separate Pega applications but are built on a shared layer. We need some way for the central team to manage requirements and plan sprints across these different projects (e.g. identify any "common requirements which could be built on the base layer). I understand that PMF allows a single application to be linked to one or more products but does it work the other way around - i.e. multiple applications to a single product?
2. Can user stories / epics be linked to requirements / specifications gathered during DCO sessions? These strike me as the same things...
Aimee
***Updated by moderator: Maryrita to add Group Tag***
