SB
UA
Last activity: 5 Nov 2015 2:11 EST
Problem in Document an Application (last SAE 1 excercise)
Hi all,
While doing the last SAE 1 tutorial excercise (Document an Application: HR Services) on the last step when I prepared a document and click 'Document Now' button, I'm getting a message from Process Commander: "Activity RequestorActiveValidate did not return expected value".
The generated WordMergeTemplate document consists of 4 pages, 3 of them are blank. There is also a message there that no table of contents entries found.
It seems there is a problem with passing data from virtual machine to MS Word through Siverlight.
Any ideas?
Dmytro
In order to resolve the issue that you are experiencing a thorough review of all of the factors contributing to the issue is required. Please submit a Service Request (SR) so that one of our Customer Support technicians can work with you on this. You can do so by contacting Pegasystems Global Technical Support through My Support Portal.
Sean
Pega Academy Support Team
