Problem changing section data layout (Formatting data elements)
Hello everyone,
I am currently working through the academy and seem to be stuck on one of the steps. In the lesson I am working I first had to create a new data model property in the applications explorer.
My next stage of the lesson required me to go into the "Collect Personal Information" step and choose "Open Section". From there I am supposed to click the "Layout" button and then click the first option which is also called "Layout". From here according to the PDF solution I should be able to set the layout type to "Dynamic Container".
The problem is that whenever I click the main layout button (The button next to the "Basic" and "Advanced" buttons) the pane will appear that has (Layout, Section, Layout Group, etc). Whenever I click on the "Layout" option nothing happens. According to the PDF which I click layout another pane should appear where I can select "Dynamic Layout" however this does not occur, nothing happens at all. I've tried resizing the window and closing/opening the test case again and again but nothing seems to work. I have also tried right clicking.
I am not sure if this is a known issue or if there is another way I can bypass this problem and change the layout for the section. I would appreciate any help as I can't imagine going further without being able to fix this.
You cannot click on these links, you want to drag and drop them into your section.
Damien
