Pega SMA does not load (due to lack of JAR scanning)
I had an issue similar to this:
https://pdn.pega.com/support-articles/unable-access-prsysmgmt-tomcat
The error was that the "struts-tags" library was not found when attempting to add a new Pega node to SMA.
I had disabled JAR scanning in Tomcat, which is required for the SMA Struts annotations to correctly load the tag lib.
I was tipped off by this article: https://stackoverflow.com/questions/38799491/error-with-struts-2-when-i-use-tomcat-8-jre-1-8?utm_medium=organic&utm_source=google_rich_qa&utm_campaign=google_rich_qa
Hope this helps someone else!
Cheers,
Nigel
***Updated by moderator: Lochan to tag post as Knowledge Share and mark as discussion.***
