Stratosphere Technical Consulting
Last activity: 23 Nov 2015 0:18 EST
Optimizing Properties in Pega
From the course:
Trying to interpret this paragraph....
To avoid this, Pega allows optimization of properties for all the standard properties such as work status, creation date and time, and creation operator, which are exposed by the product.
I just want to confirm I am interpreting this correctly. Does "exposed by product" mean that it is not necessary to expose these standard properties since they are "pre-exposed" by the system ?
Thanks.
SG
Yes, as these properties are used regularly by PRPC itself, e.g. for displaying the worklist, or for statistics on the dashboard. So these properties are already pre-exposed in the table and you do not need to optimise them yourself.
Anthem
You should be able to scroll to find the property in the Navigation Panel (left side) even with a large number of properties.
Bill Rathert
Infosys
How to find out which property is optimized and which is not?
e.g.
Need to create a report with case id and purchase order id then which property should be optimized?
Saurabh
All of the properties out of the box are exposed by Pega 7, meaning they all occupy a column in the resulting DB table. The only properties we need to expose are properties that we create to hold values in the cases we create. Both the Case ID and Purchase Order ID should be able to be looked up using the pxInsName property, you can find it on the pyWorkPage on the clipboard.
An example of a property that would need to be exposed would be, suppose we have a Candidate case and we want to figure out how many candidates are Married, Single, Divorced or Domestic Partnership. That property Marital Status is defined by us and as such the values are stored in the pzPVStream (or the blob). We would want to expose that property so we don't have to search the blob field for each record to find this information.
Hope this helps,
Sean
Pega Academy Support Team
Infosys
yeah it helps.
Bits In Glass
Hello Sean
I have a requirement where I need to generate a Report for all the properties that are exposed in my applocation.
how do I achieve this ?? Is there any wizard available through which I can get a list of all the properties that are exposed in PRPC 6.2 sp 2??
Charu
Unfortunately I am not aware of any report.
Sean
Bits In Glass
Sean
Is it atleast possible to find it in any way ..?? I need to collect this data and pass it to DB team.
