Not able to do first exercise - Using the Form Builder
I'm trying to do the first exercise "Using the Form Builder", but after creating the first form, I cannot reach it running the booking case. Also, the exercise guide is related to PVS: ui_718_pvs_20130818.zip, I don't know if this exercise guide correspond to the VM that you download.
I've downloaded the VM (UX_718_VM_20160120.zip) and the exercise guide (UIS_716_ExerciseGuide_20150910.pdf)
Any clue?
Many thanks.
Hello Sancf,
For your first exercise 'using the Form Builder', could you clarify on what do you mean by cannot reach it running Booking case? Do you mean that Booking case is not created? Do you see any error on the screen when you create a Booking case by executing Run button under Cases explorer?
For your information, the exercise download file is UX_718_VM_20160708.tar.
Also, by exercise guide(i.e.UIS_716_ExerciseGuide_20150910.pdf), are you referring this as solution guide? If yes, I find the solution guide name is Using the Form Builder.pdf.
If no, can you share the link used to download UIS_716_ExerciseGuide_20150910.pdf.
Rincy
