import fails
for Exercise 1 you need to setup the environment by importing a jar. When I hover ovre "appliation" in the Pega Marketing Enablement 7.13 VM, nothing happens. So I can't go forward to hover over "Distribution" and click on "import". the expanding on hovering over these items does happen on another VM from Pega. Is there something I can do to fix this? Thank you.
I have downloaded the virtual machine again, but I encounter the same problem. The VM is in the folder with name marketing_713ml9_pvs_20151201.
