Import failed
I tried to repeat the exercises for the courses SAE I and II. There exists an application from the first run in pega. I have created a new application and tried to import the file
"Background_Check_Components_2014_0520.jar ".
I get the following error:
There is nothing to import -- the rules contained in this archive are already present in the database.
How can I use the already existing rules for the new application?
Manuela
The rules found in this .jar file is already imported into the SAE II exercise system when you start the course. So there is nothing to import again. The rules in this .jar contains the Data classes (you can see them when you switch to the Data Explorer) for completing the SAE I exercise "Reusing Data Transform for Background Check".
Look through this exercise to see how to use the rules imported from the .jar file.
