   PEGA
   PEGA
          Posted: Jan 23, 2021
        Last activity: May 26, 2021
      Last activity: 26 May 2021 15:15 EDT
Implementing BLOB and Property Encryption
If you want to encrypt the BLOB and properties, either in a new or an existing application; the attached implementation guide will help you step by step. The document also includes a deployment plan to make sure the encryption is applied correctly in other environments.
@MITTS
Contents:
- General
- Pre-Project Considerations
 - Setup
- Step 1: Configure KeyStore
 - Step 2: Activate KeyStore
 - Encryption of BLOB
- Removal of class instances
 - Encrypt BLOB
 - Encryption of exposed properties
- Access Control Policy
 - Column Length
 - Encryption in Exposed Properties – Issues and Design Patterns
- Section Rules – Visibility conditions in expressions
 - Validation Rules
 - Data Transforms/Activities
 - Full Text Search
 - Reporting
 - BIX
 - Deployment
***Edited by Moderator Marissa to update Content Type from Idea to Discussion; added Developer Knowledge Share tag***
