Encryption of property values at BLOB level
Hi Everyone - I have Created a class with a unexposed property and in Blob , As per PDN article , if we need to encrypt the blob data , we need to select the checkbox Encrypt BLOB ? on the Rule-Obj-Class definition.
Once this is done and all the Pega encryption utilities are executed successfully and class is in db , and prconfig values set . On the PRPC UI, entered value for this property and saved it in db .
How do I make sure or check if the value for this property in the BLOB is in encrypted format.
After doing a obj-open, Obj-Open-By-Handle and Obj-Browse , the value that displayed on the clipboard for the BLOB are decompressed and decrypted .
I need to check the value for the property in the BLOB in encrypted format. Is there any way to get that?
I have done the encryption/decryption for few exposed properties with type as TextEncrypted, need to check the same at the BLOB level
Danny
