Infosys
Icon is getting changed in Tabbed Harness screen
We have upgraded the system from 6.2 to 7.1.8. Post upgrade we found issue with upgrading WorkArea to Dynamic container. We have 5 harnesses into the WorkArea and those are from different class hierarchy. So automatic upgrade option is not comng here. We can change it manually but that is taking time. We have more than 10 such sections with WorkAreas. Is there any other way to change those?
There is one more issue. The images on the tabbed harness are getting changed when the Harness is loading fully. We have shown some other images but those are getting changed to default image for case. Any solution for this issue?
WorkArea to DynamicContainer would be a manual task as the Harness rules are from different classes rather than Data-Portal class.
For the second issue, can you try to configure the image in the Case Designer for the case. I am not not sure what is actually happening as i do not get to see the screenshot or recording, but based on your explanation I feel that the case desginer icons are taking priority.
