Bank Of America
Last activity: 30 Mar 2017 16:41 EDT
How to capture incoming Request XML for Service-SOAP
We have Service-SOAP rules in Pega 7.1.8 which is being consumed by another application. I want to be able to log the incoming request xml for each invocation. When I trigger the service manually/SOAP UI, I can see request xml soap envelop on tracer if I keep tracer option "SOAP Envelop" enabled, but it shows up well before service activity starts execution. I want to be able to store this SOAP Envelop request.
Currently I am just using @getXMLOfPage(MyServicePage), but that logs entire page xml, which is not something that I am looking for.
I know that we can also enable logger and have these logged to pega logs but even thats not something I am looking for.
Any suggestions would be appreciated
***Updated by Moderator: Marissa - Thread has been archived for educational/information purposes. If you have a similar question, please select Write a Post and start a new thread for assistance. No information in thread will be updated.***
could you please try a sibling method: @(Pega-RULES:Page).getXMLOfPageWithoutPageDataTag
Coforge
Hi
Complete request xml can be located at pxRequestor.pxReqSOAPEnvelope. Hope this helps to solve your problem
Updated: 18 Feb 2016 18:09 EST
IT
SK
It works for me on PRPC 6.3!
This is fantastic, I was looking for it for a long time. Thank you, Bhaskar.
This is also strange: in 7.1.5 I logged entire pxRequestor and did not see the captured inbound XML.
@All
What version do you use and does the instruction from Bhaskar work for you?
Bank Of America
Thanks for your inputs
IT
SK
Do we have similar way to capture Request XML for Service-HTTP?
Cannot see it on pxRequestor.
CGI
Does
Bank Of America
I am also having the same issue with 7.1.9. Did you find a fix or alternative solution?
IT
SK
works for me for SOAP Service (not for Connect SOAP), could you, describe the issue you are facing?
Wipro
I have a requirement to Save SOAP service response XML in Logs. we are using PEGA 7.2v
please advice how we can do it.
Adarsha M
This comment has been branched out as a new node and the new thread can be followed here
Charles Schwab & Co., Inc.
I am also having this issue - the property pxRequestor.pxReqSOAPEnvelope does not exist in 7.2.2. Please advise.
Hi Stephen,
This is an older thread and I branched the comment above you into a new thread. Please see that thread for future assistance. I'm closing this one to future comments.
Thanks!
