Last activity: 30 Nov 2021 7:50 EST
High level overview of test coverage using PegaUnits
Test Coverage is a feature to improve the quality of your application and identify how many executable rules in your application are covered by tests, be it UI manual tests, PegaUnits , Scenario Tests or other UI based automation tests.
More information on Test Coverage feature can be found in the link below:
If one wants to get the coverage of just the PegaUnits, this article explains how to get it.
Step 1: Start the coverage
Click on Configure->Application->Quality->Test Coverage
One would be redirected to the application coverage landing page
Once landed, we can find a button to start the application coverage, click on "Start new session", provide the description of the coverage and click "ok" to start application coverage.
Note: User should have privilege "pzStartOrStopMasterAppRuleCoverage" to run the coverage.
Step 2: Run PegaUnits
Go to PegaUnits landing page and run the PegaUnits.
Go to Configure->Application->Quality->Automated testing->Unit testing->Test cases
We will be redirected to the PegaUnits landing page, try to select the PegaUnits and run them.
Once we select all PegaUnits in first page, link will be shown to select all PegaUnits in all the pages. Click on the "Select all "XX" tests in the application".
Note: List of PegaUnits shown here are based on the list of applications selected at "Application Quality Setting". You can see Application Quality settings at Configure->Application->Quality->Settings.
Below is the screen shot we can expect to see
Step 3: Stop the Coverage
After running the PegaUnits, go to the coverage landing page again and stop the coverage.
Configure->Application->Quality->Test Coverage.
Click on "Stop Coverage" in the landing page header.
Once the coverage is stopped, a coverage report will be generated, and it will be shown in the list of coverage records.
Step 4: Check the coverage percentage
We can check the coverage recorded for running PegaUnits and we can also click on “Show report” to see the details of coverage report, like the rules covered, uncovered and other details of coverage session including logged in user’s name that performed coverage.
Note: List of rules considered for the coverage session are based on "Application Quality Settings".
Below is the screen we can expect to see
