Mindtree
Last activity: 29 Sep 2015 8:52 EDT
Hi Usually all the properties are associated with two names label name & property name.If I want to have only one either of
Hi
Usually all the properties are associated with two names label name & property name.If I want to have only one either of this how to do this.
SG
Just use the same value for both label and name.
Mindtree
Actually what I wanted is I want to disable one of them. Anyhow during runtime only one name appears.
Anyway thanks a lot CHAUT.
SG
Unfortunately you can't "disable" any of them. It's built into the property itself. :-)
The description is actually the label used when the property is used in the section.
You can uncheck the field that sets the label equal to the property description and then remove the label/description all together. The only value remaining to be seen in your section would be value of the property.
Bill Rathert
Mindtree
But in that case property will not have any label right..:).. I want to have either of one depending on my requirements.
You are correct, the property will not have a label. Can you give me an example of you rrequirements. You could add the a label next to the property in another cell. However, you are getting into a lot of extra work and breaking best practices.
Thank you,
Bill Rathert
Mindtree
No RATHW..I am not breaking any practices..Under UI gallery in one of example I saw something of that kind...So thought of understanding it.Actually I closed it in my first reply only you guys kept going...:)
No,I did NOT say YOU were breaking best practices. I said using the example above that I stated would break best practices.
Bill Rathert
