P3Fusion Inc.
P3Fusion Inc.
P3Fusion Inc.
Posted: Sep 16, 2024
Last activity: Sep 16, 2024
Last activity: 16 Sep 2024 9:12 EDT
Customizing fonts for your PEGA Application
- Choose the font from https://fonts.google.com/
- Select the font you want to use.
- Download All
- Your font will be downloaded as Zip file
- Extract the Zip file
- You will find fonts in TTF Format as below,
- Select the TTF file which you want to convert to WOFF2
- Use this site for converting https://www.fontconverter.io/en/ttf-to-woff2
- Upon converting, you will have the option to download,
- Download the Zip file
- Extract the Zip, The Zip will contain TTF,WOFF2,CSS file.
- In the header of Dev Studio, select Create > Technical > Binary File to create binary files.
- In the App Name (Directory) field, enter webwb.
- In the File Type (Extension) field, enter the corresponding font format (.ttf, .woff, or .woff2)
- Create and Open
- In the File controls section, click Upload file and select the corresponding font file (woff2).
- Save
- Open Application Definition — Under Presentation you will find the skin which application is referring to
- Select the Skin in which you want to make changes
- In the Skin rule form, Select the Included styles tab
- In the Additional style sheets section, click + Add style sheet
- Create and open, upload the CSS file you have created
- Return to the Skin rule form and click Mixins
- In the Typography section, click General
- In the Font family list, select other
- Enter the font
- Click Save
- Check your UI
***Edited by Moderator Rupashree S. to add the Developer Knowledge Share tag***
