Mphasis
Mphasis
Mphasis
Posted: Mar 16, 2016
Last activity: Jun 29, 2016
Last activity: 29 Jun 2016 21:38 EDT
my application is upgraded to 6.x to 7.1.x. In a listview instead o f getContent activity a customized activity is used. I want to change this listview to ReportDefinition. Please suggest the right process.
Hello SudheerP2393,
There is no way to convert a ListView to a Report Definition rules. You will have take the existing ListView and create a Report Definition that implements the same functionality.
Andrew
PDN Support
If there are a few reports, change manually.
If there are like 50 or more, write an activity to convert list view to report definition. You'll have to analyze the clipboard structure of list view rule, take those properties and set those to clipboard structure of report definition rule and save it with new name. This is quite complex.
