Last activity: 10 Nov 2024 0:39 EST
CLSA Community: Pega GenAI™ and the LSA - 24.2 Edition (October 2024)
During this session, we coverered:
- Recap of takeaways from last year's session
- Advancements in Generative AI over the past year
- Pega GenAI enhancements in the 24.x release
- Generative AI in Action: Real Use Case Demos
- Pega GenAI architecture
- Looking ahead: 2025 Roadmap and Industry Trends
Reply
Jose Navas -
Updated: 6 Nov 2024 8:53 EST
Hcl Netherlands BV
@DianeSK Hi Diane , Is it possible to feed case documents to pega gen AI coach ? if possible could you please add more light on how?
@SritejaLSA I believe so, if not by using the Default Coach, then by creating your own coach. I'll add our friends @rawap & @ArunSarada to confirm.
Updated: 7 Nov 2024 2:05 EST
Yes, providing case documents to the Pega Gen AI Coach is possible. Currently, Coach supports only text content, so if the attachments contain purely textual information, you can configure a data page to feed this data to Coach. We're also working on enhancements for the next release that will enable the Coach to read more complex document formats, such as DOCX and PDF files, including elements like images and tables.
Refer to this link for more details on Coach configuration https://docs.pega.com/bundle/platform/page/platform/case-management/peg…
Hcl Netherlands BV
@rawap Thanks for your reply .We tried sending word document as byte stream but as you said it could't understand the content as it only understand the text content as of now.
Also when I send stream of document(word document with three pages) content to coach then it responded like 16385 is the maximum token limit for this model.Hope this will be taken care in the next release since its common that case documents can have more than three pages.
@BhanuPrakash_G - Hello! Yes - see the event replay page.
Updated: 8 Nov 2024 14:37 EST
SoftServe
@DianeSK Hi Diane,
Do you know if Pega GenAI PremBridge can be used to bring GenAI capabilities to legacy applications, i.e., non-Constellation apps? or in a more general sense, do Pega GenAI capabilities (Coach, Connect, etc.) will work with UI-Kit applications?
@josenavas Hi Jose - from what I can glean, it appears the only requirement is that your client managed applications need to be on 24.1 to use PremBridge, Constellation or otherwise. It also appears that you do not need PremBridge to use Knowledge Buddy. I've looped in @ArunSarada to confirm.
