Business Extraction - GenAI
Objective
The objective of this initiative is to leverage GenAI‑driven Business Extraction and Rule Intelligence to streamline understanding, documentation, and modernization of Pega applications. By automating the extraction and interpretation of rule logic, this approach accelerates onboarding, enhances application insights, and reduces the manual effort traditionally required in modernization and assessment activities.
Technical Process
Import the Business Extraction Tool
Install and configure the Business Extraction component within the Pega environment. -
Launch the Rule Analysis Portal
Access the portal and initiate the automated workflow to perform rule‑level analysis. -
Extract Rule JSON
Generate the Rule JSON artifacts representing rule metadata, configuration, and logic. -
Sanitize Extracted Data
Remove sensitive information and filter out unnecessary details to ensure clean, compliant inputs for downstream processing. -
Invoke GenAI for Business Interpretation
Use GenAI to generate human‑readable business descriptions for each rule based on the sanitized JSON. -
Derive Application Insights
Apply these generated business descriptions within context of:- Class inheritance hierarchy
- Rule reference and dependency structures
This allows a consolidated view of business logic across the Pega application.
Business Advantages
1. Rapid Onboarding
Provide new team members with business‑level explanations of rules, significantly reducing the learning curve.
2. Accelerated UX Modernization
Supports modernization initiatives such as:
- Channel‑specific UI transformations
- Alignment with the Signature Tool
- Streamlined identification of outdated or redundant rules
3. Reduced Modernization Assessment Effort
Automates what is traditionally a time‑intensive manual analysis of rules, lowering overall assessment effort and timelines.
4. Knowledge‑Ready Artifacts
All outputs generated through this process can be fed into Pega Knowledge Buddy, enabling natural language conversations and contextual assistance for Pega users.
