Booz Allen Hamilton
Last activity: 11 Sep 2015 22:18 EDT
Building Assignment Focused (Intent-Driven) User Interfaces
" If you click the Run button to test your Create Employee Record step in the Onboarding case type, but don’t see the UI section appear, ensure that you’ve done the Adding Default Data Transforms exercise and that the Employee page properties have been correctly initialized for the Onboarding process. "
I have added the data transforms as per the lesson and also created the section as per instruction, but still i am not able to see the UI section when i run. Where am i making the mistake. Please help.
Thank you.
SG
Check your clipboard for pyWorkpage and see if the .Candidate embedded page is created, and if it is, what are the values of the page.
Booz Allen Hamilton
The pyWorkpage is not created and i do not know why?
Booz Allen Hamilton
If i run the section it is not created. But if i run the case type the py Workpage is created in the clipboard. But since we cannot see the section the information cannot be entered.
SG
The pyWorkpage represents a case. You will not be able to find the pyWorkpage without running a new case. If you simple run the section, the pyDefault will not run. It is only run when a new case is run.
Booz Allen Hamilton
But still why the section is not seen when we run the case?
SG
Can you check to ensure you have specified the page name as ".Employee" and not "Employee"? The '.' is significant when you perform the section include.
Booz Allen Hamilton
Yes i have given the "."
SG
No, I mean in the section include in the Create Employee Record section.
Booz Allen Hamilton
Yes, i have missed the "." in the section include. Thanks for your guidance.
SG
When you reference a property in Pega 7, you use '.' in front. Now remember that Employee is also a property of the Candidate class, just that it is a page mode instead of value mode,. So when you reference it you also need the '.'.
