7.1.7 PE - is 32 Bit PE available
Hi Team,
Most of the Personal Laptops are 32 Bits, while the PE 7.1 is 64 Bit Edition.Is it possible to make 32 Bit available for general public.
amit
Hi Team,
amit
Question Solved
Question Solved
Amit,
Unfortunately it is only available in 64bit, If the laptop supports 64bit but just your OS is 32bit then you may have luck running it in a VMWare VM, if you aren't sure there is a utility to check available from VMWare.
Sincerely,
Cecil Howell
